Good evening all.
I'm in the process of redecorating our bathroom and have chosen Marble tiles for the wall's (and riven slate for inside the shower, may reconsider the use of these).
Glueing to Hardwall?
We've had the walls plastered, and it's been finished with hardwall, as opposed to skimmed. I've had a look online and there seems to be varying opinions on whether or not i can tile directly on to hardwall, one guy that sees to be talking the most sense that though hardwall is not recommended to be tiled upon, so long as the wall is damped first (to stop the glue being sucked dry before setting) then there is no problem at all. Echoed by people here?
Grout Colour
The tiles we've bought are http://www.thenaturaltilestudio.com/products.asp?Product_Id=Crema_Marfil_Select_Marble.htm (but from B&Q so slightly cheaper). The site recommends the use of a grey glue and grey grout, I know it's a judgement/taste call usually but Grey? Really? From people that do this daily, hows that liable to look? What about some thing closer to egg shell white (if you can buy that), so not dark grey but a fairly light grey?
Glue
BAL seems to be mentioned quite a bit in the sticky, I assume this is a good indication that it's a good brand to go with.
This seems to be the glue the recommend for use with natural stone however it's only available in white. http://www.bal-adhesives.co.uk/products/natural-stone
This one seems to be for natural stone as well, http://www.bal-adhesives.co.uk/products/rapidset-flexible, is this suitable?
Is it worth while using their AD1 additive? http://www.bal-adhesives.co.uk/products/admix-ad1
Based on other posts, I know that I'll be putting glue on the back of the tiles as well as the wall to avoid the appearance of shadows.
Grout
I had a look through their grouts and I couldn't find any that seemed to say they were okay to be used with Natural stone, is that because they are not, or that they all are?
Assuming the tiles have been sealed properly, is it okay to apply grout in the usual manner using a grout float?
Sealing Tiles
Assuming we are tidy when putting the glue on, is it required to seal the tile before putting it on the wall, or is it possible to seal once they are stuck to the wall?
I read some where that when sealing the tiles, i have to be careful NOT to seal the edges (I assume allowing the grout to adhere to the tile), however I've now seen conflicting suggestions. So, when sealing a tile, do you seal the entire thing, or just the surface? I can see possible reasons for each
We've done some tiling in the past (kitchen and bathroom), but it's with normal tiles as opposed to marble, and I'm just a little nervous, as their a lot more money
And help/advice would be very much appreciated.
Doug
Grout Colour
Glue
Grout
Sealing Tiles
Doug
