I am getting quoes to re roof a felt garage. The garage has metal trusses that run between the two walls. On top of this is OSB board which is then covered in felt. The felt is leaking something awful and as such the OSB boards are rotten and bending. The roof has been leaking for a very long time! The boards and the felt all need replaced.
I had a local guy round today to have a look at in order to give me a quote. He suggested replacing the OSB with ply and at one point suggested marine grade ply. TBH this kinda set alarm bells ringing as I don't really see the need to use this and feel it would be expensive overkill.
Having said this, I am not a roofer and perhaps the guy was looking to make sure the job he did would last long (ie if the felt failed, the boards would last until it was repaired, but then again isn't OSB designed to be used outside- I'm thinking boarded up shop windows etc).
Anyhoo, your thoughts would be much appreciated on this.
Cheers
Cheers
