Finished the kitchen and got round to the floor,managed to get the old Marley self stick tiles up after a lot of hard work and have got the new one's to go down,the supplier said use Ball f45 acrylic adhesive saying this will be okay on asphalt,reading the instructions it says you should use a neoprene primer after washing and then Stopgap300 and lay the tiles on this.
Given the grief i had getting the old one's up which were laid straight onto the asphalt and have been down for fifteen years i tried a piece of tile straight onto the asphalt and it seems to be well stuck after 24 hours,the floor is level apart from a couple of area's that i will remove and fill and then use some Bal apd to seal the cement,just need some input on this one regarding the suitability of the f46 and the chance of a reaction/failure of the adhesive.
