Marmox Showerlay Drain Solvent weld connect to push fit?
7 Apr 2008
Nottingham
Hi all, i'm having a nightmare with this.
I;ve got this http://www.tilefixdirect.com/product/MXDRAIN.html and need to know how to connect it to the rest of my waste system.
As it stands I wanted to connect this to my bath waste which is 40mm pushfit however I understand this is not possible?
I can run this straight outside but want to connectec to the bath outside to go into one waste pipe run down the drains just so it looks neat.
Any ideas?
I dont really want to have to go out and buy all kit needed for solvent weld stuff.
The outside is 50mm so a uni pipe thing like http://www.screwfix.com/prods/81383...n-Waste/Flexi-Waste-Straight-Coupling-38-45mm wont fit either?
Plus its a rip off for a bit of rubber pipe and two metal rings!
Sorry bath waste trap Is compression which I have connected and then the rest of run is push fit.
I just dodnt want to buy a whole tub of solvent to use on one joint but if thats the only way I have to buy solvent waste pipe too?
Solvent weld waste is better - no chance of it pulling apart or losing it's seal. You can get half-size tubs of solvent weld if you don't want a big one. SW waste pipe should fit in your trap's compression joint
