I hope someone can help. I'm desperate
I have a massive airlock in my heating/water system. I’ve had the pump changed (along with something else – a thermostat on the water tank I think) and had the boiler off the wall to ensure the heat exchanger is not clogged. All this was done 3 months ago and system was bled 3-4 times at the same time (all to get rid of an airlock). I also had the whole system power flushed at that time.
Since then, heating has got progressively worse - and the air lock is now back. I am now bleeding rads bottom-up every day. 99 times out of 100 there is no air in the rads. I regularly hear a crashing/banging in the system and can hear a gush of water from the overflow (?) into the header tank in the loft. Occasionally, say 20% of the time, the boiler goes to overheat. I then re-bleed the rads, shut the power to the boiler, wait 15/20 mins and restart. All then works but I will get the crash/bang.
Can anyone offer advice/help on what I should do next? The airlock resolution has cost me, so far in excess of £1300 and I can’t afford to blindly call people out anymore. I’d rather try to have lots of info/ideas so the engineer “thinks” I know a bit about this sort of thing and does not try to rip me off.
I have a 5 year old Baxi boiler (with, apparently, no drain off valve).
All help and comments appreciated.
Thanks.
Thanks.
