Hi all,
I am after a 2nd opinion. My sister has recently moved into a masionette. Last year they had no problems with condensation. During the summer, they had all the windows replaced for double glazing.
Since the cold weather set upon us they are suffering from massive, and I mean dripping down the walls condensation. She was so shocked by the amount of water that she thought a pipe was leaking. I was sceptical, but I've seen it with my own eyes tonight, and the condensation is certainly vast.
I went up in to the loft, and after poking about, found no leaks (there aren't even any pipes over the affected rooms), but found that under the fixed down floorboards in the loft (after taking up a couple) there is NO insulation whatsoever.
Could this be the cause of the problem. I ask as last year it was OK. Has the combination of the new windows, and the colder weather caused this condensation problem?
If so, I will get down to Wickes tomorrow and get insulating for her.
Any thoughts?
Thanks in advance...
Any thoughts?
