Im about to re-instate a stud wall to seperate 2 rooms. I dont know what the previous wall was like but the boxed in joist on the ceiling and on one wall is 145mm thick.
As far as matching the thickness of the wall to the boxes(to make plastering easier), I was thinking of 2 x 12.5mm plasterboard, 100mm timber which leaves 10mm on either side left to skim(quite a lot for plastering).
How much do I need to leave, if any, to allow the plaster to be skimmed. I am planning on skimming the whole wall to produce a better finish.
I was thinking of adding a 9mm plasterboard to one side which leaves a total of 11mm left to blend in. 5/6mm either side.
Is it ok to double up on plasterboard?
thanks, Jack
thanks, Jack
