Matching victorian 12 inch skirting board help!
12 Aug 2014
Yorkshire
I am trying to match up this 12 inch victorian skirting board, i have rang my local wood merchant who wasn't much use. I've tried the usual DIY places, wickes b&& q etc with no luck.
Any ideas of online stockists? It will be getting painted so It doesn't matter what wood or mdf.
It will be such a shame to have to remove it all if I can't match it :(
You have to take a section off or do very accurate drawing and take it to your local joinery work shop,they will mould sections for you,the skirting could be made up of 2 to 3 different sections depending on pattern
as Harbourwoodwork says will more than likely be 2 or 3 bits joined together
look for architrave off the same profile and glue to planed timber or sheet material to make up the size
