Hi All,
As a backup plan if our house doesn't sell I'm looking into the possibility of an extension, I want to apply for planning permission whilst it's on the market so I'm ready to start building the day we can take it back off, whether we go ahead with the extension will all be down to cost and there's a few things I need a hand with.
Here are the plans and a few pictures of the house currently.
I'm basing the design on the idea of building 3 brick piers where the 3 6ft fence posts currently are with rsj's on top of the pier and garage wall then 2 maybe 3 across to the house to make the floor (A structural engineer will be used for this if the costs look viable)
I'll be doing all the labour so the prices are purely for the materials,
Roof Tiles/Battens/Membrane £1000
Roof Trusses £1000
Brickwork & Piers £1000
Foundations £1000 For 14m Trench 600mmx1m deep If I have to replace garage foundations
I need help with what the rsj's may cost and what will be required, The new rooms above the garage will be housing 2 bedrooms and obviously the roof will be a reasonable weight is my idea of using 3 piers feasible or would I be better using steel columns covered in brick slips.
Also how would I seal the bottom of the floor from the outside weather? inside the garage I could just insualte between the joists and plasterboard as required but what would I use outside the garage door, I assume there's a plastic sheet material for the job?
I'm hoping to be able to build the weather sealed shell of the extension for 10k or under with a total finished cost of 20k depending on exactly what we do internally.
I've not costed the windows as the odds are we would replace all the windows in the house which would be a seperate cost to all this work.
Also with regards the roof as there is already a small extension on the rear with a pitched roof draining onto the flat garage roof I planned on draining the rear of the new extension roof onto the roof the same, I can't see a way of fitting any sort of pitched roof to the garage roof so think a flat roof on the garage is the way to go
Chris
Roof Trusses £1000
Chris
