I may be foolish but I want to have a go at building a garage myself and unsure about which type of construction to use
Currently in place is a detached timber item that is solid but leaky draughty and has no solid concrete floor just old paving slabs and rubble from where the old outside toilet used to be
Obviously the first thing to do is get a load of mates round and Kung foo its ass and Knock it down and then put a concrete base down using the mesh stuff and putting in decent foundations for the wall, but then, this is the bit, what do i build it out of??????????
I looked at some old 70's mags on how to build garages (obviously things have evolved somewhat) but what type of brick/block do I use???
I had thought a couple of coarses of engineering bricks a Weather bead?? and then 100mm concrete block things and render it??
Would this make sense, I'm far from minted hence why I want to have a go, so cash is an important factor in this build
I want the garage is to be in big enough for a family car size plus a bench etc..
Any advice on materials and techniques etc would be greatly received,
P.S. I got one of those Brickies mate things to help me build was I done???
P.P.S I built a barbeque once........... it fell over.
