What are the rules governing LPG Supply Pipes? How long can the distance be between the point at which the LPG Supply Pipe enters a building and the LPG Boiler?
OK. In that case, are there any rules or guidelines for how you run the pipes through a building. For example, is it OK to run in ducting in the floor screed or embed pipes in walls? I am presuming that its best to surface mount...
Is there a more robust pipe (other than plastic coated copper)?
BSi Kitemarked to British Standard BS7838, TracPipe is suitable for natural gas, propane or butane, (1st 2nd and 3rd family gases), at working pressures to 75mbar.
