Hello.
I am planning to have my cottage rewired and have done some initial planning. I have already called out the electric board to come and uprate my fuse in advance but they want a Max Demand figure. There is a sticker on the present fuse which says it is only rated at 60 amps and I think I need it to be of a higher rating. My brother's house has a 100A fuse.
This is all still in the planning stage and I would like to get the electricity board to come and fit an isolator as well as fit a higher rated fuse.
Then I can ask the electrician to come in and make a start on rewiring.
My planned circuits are as follows
Ring 1 - no of points served = 6 B32A
Ring 2 - no of points served = 7 B32A
Radial 1 - no of points served = 9 B32A
Radial 2 - no of points served = 4 B32A
Cooker point - no of points served = 2 (1 is the built-in socket outlet) B32A
Radial 3 (Central HTG) no of points served = 1 B6A
Radial 5 Lights down - no of points served = 17(inc 12v Bathroom fan)B6A
Radial 6 Lights up - no of points served = 7 B6A
Radial 7(6.0mm sub main to garage) B32A
Garage fusebox
Garage will comprise of
2 x lights on another B6A
2 x double sockets , each on it's own B16A trip switch
What would be the Max Demand figure for the whole lot and how do you work it out.
Thank you in advance.
William
Garage fusebox
William
