Hi, Just looking for some help if you don't mind? If I have a hot tub which is rated at 20A, then + 25% would mean a 25A MCB... but since I can't seem to find 25A MCB's anywhere... what do I do? Surely if I go for a 32A, then I'm risking damage to the hot tub should a fault occur?
Interestingly... the hot tub has 16A stamped on the plate where the mains connection is. Though the total power rating is 4.7kW (hence 20A)???
