I've recently been having trouble with my immersion hot water system, we have three switches, one serves the pump into the hot water tank, the other two serve the heating elements (one on the top and one on the side of the tank).
The circuit breaker for the hot water system started tripping off several weeks ago but only very occasionally. Now it's tripping more frequently. I tried changing the switches for new and I changed the thermostats in the immersion elements (as they're fairly easy to do).
I noticed last night that the circuit breaker tripped off even when all the switches were turned off. I even disconnected the wiring from the immersion elements and the same thing happens. So I've established that the fault doesn't lie with the elements, is this likely to be a wiring issue - perhaps a faulty earth?
