We have a McCulloch MT320 strimmer, not sure of the age but probably over 10 years old. The handbook gives quite clear direction on carburettor adjustments which are the normal idle speed, "L" and "H" screws as found on similar small engines. Recently it's been giving trouble, getting hard to start and not running well. I've fitted a new plug as a precaution, and cleaned the air filter before trying to adjust the carb. This is where I'm finding an issue. If I get it running nicely at tick over, it won't rev up properly. The "H" screw makes no difference at all whether fully open or fully closed. I can get it to rev properly by unscrewing the "L" screw further, but then it won't tick over so that's clearly wrong.
My question is about this "H" adjustment, which I believe controls fuel flow at high speed. I had the carb in bits and I'm pretty sure none of it's passages are blocked, so is it possible that the fault is caused by a leak elsewhere or by a stiffened or distorted diaphragm?
The machine is no longer supported by McCulloch so I don't know how easy it will be to find a compatible repair kit or replacement carburettor, so I'd like to see if I can understand the issue before searching for bits.
Thanks, Tony S
Thanks, Tony S
