Hello,
I have just had some floorboards up in a bedroom, to inspect the pipes there under and the original timber floorboards are in bad shape. The person below was also complaining of squeaking boards; the original floorboard nails have been in and out a dozen times I would guess, and some non standard 2" nails used in places. The existing boards have areas of dry rot or wood worm and so split when the chisel kissed it. So patches need replacing. The joists are sound.
The existing boards are 3/4" thick and 6" wide. I would be replacing three or four joists width (12" spacing, joist 2-3" width) so the longest strip would be ~150cm (60"). They would fit snugly under the skirting at one end.
I have read on here to NOT use MDF, but some of that advice was going back ten years. For reasons including: it would null your insurance; not load bearing; it would warp over time; screws will move and squeak; water damage, etc.
Well, I have just been given from a skip some MDF off cuts which are 22mm thick (ideal), 15cm wide (perfect) as well as some which are 40cms and 6cms (perfect as a triple). I couldn't believe my luck.
Based on those measurements, bearing in mind it will be a low traffic floor (bedroom) and be partially covered by the wardrobe, do you think the MDF would be strong enough? Fixed down with no4 55mm screws.
The existing underlay and woven carpet will go back down.
Please say it's fine as I've started already... But now reading on here and I'm beginning to worry.
