Hello everyone,
I'm in the process of considering starting a project, if you know what I mean, and there's something I hope you can help me clear up.
The plan is to build a case out of MDF, approximately 40*40*30cm, which will involve cutting the pieces of MDF to length, and also cutting holes into some of the panels.
I was thinking of using 10-15mm thick MDF, and am wondering what tools would be suitable for the job.
I'm considering getting myself a dremel-type affair, to deal with some of the more fiddly bits, but am doubtful if this would be suitable for cutting 40cm straight edges through 15mm board. If this is the case would a cheap and simple jigsaw be more what I'm after?
Thanks in advance, any info or opinions would be greatly appreciated.
