I'm running a new water supply. From the meter it will tee off; straight ahead for a garden supply and right for the house supply.
I'm running 32mm MDPE from the meter, 25mm for the garden and 32mm into the house so I want to reduce "the straight" down to 25mm rather than on the 90 degree tee.
Does such a tee exist, or should I get a 32mm tee and reduce down after that? I'm trying to avoid as many joins underground as possible.
