MDPE flange fittings
18 Nov 2017
Hi
I've got some (beginner) queries I'm wondering if you could help me with..
1, Could I use a Plasson 'Compression Flange Adaptor with Metal Flange' 50mm/2" (http://plasson.co.uk/catalogue/grou...on%20Flange%20Adaptor%20with%20Metal%20Flange)
in combination with a 50mm to 32mm reducing set to connect 32mm mdpe pipe to the flange adaptor? I know this is probably a yes, I've just not done any plumbing in the last couple of years.
2, If you already have a fitting on the end of mdpe, is it possible to remove the fitting and replace it with another or do you always have to cut off the section of pipe the grab ring bit into?
Cheers
1. Yes, sounds ok.
2. You don't have to cut the pipe if it is in good condition. Although if you have enough to play with I probably would.
