Mdpe to copper tee
8 Jun 2010
Sussex
Anyone ever seen a mdpe (20mm) to 15mm copper tee?
I can’t seem to find one and space tight for reducer/pipe/tee.
Any other suggestions?
Side reduced, end reduced, side and end reduced or both ends reduced?
Anyway: 20mm equal poly Tee plus one or two of the brown 20/15 reducing kits eg Floplast screwfix 65438
A Philmac 20mm tee and a couple of Philmac copper adapters would do it
yes it would but that would mean three adapters, the tee itself then 2x reducers. I was hoping to do it in one but I’m guessing it’s not the case now.
I probably just use a 20-15mm reducer then a n equal 15mm tee. Hopefully make it fit as limited space under the floor.
Yep posted the wrong size but picked up the correct one today thanks muggles.
