Means of escape windows on a second floor ?
20 Mar 2010
West Midlands
I'm a little confused about installing windows in two bedrooms on the second floor.
The first window would replace an existing window, the second one would be a 'Velux' type window which will be fitted into a room that doesn't currently have a window (originally there was glass above the door which let light in from the landing)
But, have been told I can't install 'means of escape' windows in these rooms because they are too high off the ground, so what should I do ? There is no protected escape route and it's impossible to make one because the stairs exit into a lounge then kitchen before the exit to outside.
Any ideas ?
Was going to post on the 'Building regulations' forum but I thought I'd try here first :D
If the above is unsuitable there are other models which require an anchor bolt fitted below window and the ladder is then clipped to this before use.No risk of movement while in use.
If you are replacing windows to existing rooms, then you only need to ensure that the windows make means of escape no worse than the current windows
For that room with no windows, then again if fitting a new velux then means of escape wont come into it. But if you have just made this room, then you will need to provide a means of escape (or other precautions) if the room is a habitable or frequently used room
