Mechanical timer doesnt work - is that because of the thermostat?
2 Nov 2015
I have a boiler which is operated by a programmable thermostat. However the mechanical timer on the boiler doesn't work. Is it meant to be like that? i.e. if you have a thermostat installed then mechanical timer becomes redundant?
Thermostat is Salus RT-500F
Boiler is Baxi 30Kw
JH
The thermostat also contains a timer - you set both temperature and the time you want that temperature.
The mechanical timer is not required, and has probably been disconnected, but left in place to avoid having a big hole in the front of the boiler.
