Hi all, done some reconfiguring of the onsuite and decided to lose some space and put in a smaller shower so we can install a vertical cyclinder not the horizontal one.
I have two questions to clarify what the installer has said:
1. is megaflow the best to go for or are there cheaper/more expensive ones that are just as good??? he does seem to push them alot and disgards other that i know are on the market.
2. I have a poly main he thinks is 20mm and then 15mm around the house as have storage water tanks - he says that this may have to be upgraded to 22mm certainly from the poly but depending on flow rate may have to go back to the meter near the road.... is this correct?????
or can a megaflow or similar take 15mm if the flow rate/pressure meets the minimum requirements???
Thanks in advance
Thanks in advance
