Hello,
I have a MegaFlo hot water cylinder model - CL250HE
The copper over flow pipe from the PRV runs to the outside of my property, and recently I have noticed that it has been discharging, notably when the hot water timer on the boiler has been on, but we no hot water has been run.
As a matter of interest, also, when first turning the hot water tap on the tap feels almost "stiff" then after the tap has been running for a few seconds the flow rate slows
I am pretty sure that this is all related to the pressure setting on the PRV (a small brass type screw?) But I am unsure how, if at all, I should adjust this.
This is a brand new house <12 months old, should I call the builder back in? (as the house and it's appliances are covered by a 2 year warranty)
Also, the instruction manual for the MegaFlo advises the end user to switch the appliance off and discontinue use until this has been looked at, is it something to worry about?
Thanks.
Thanks.
