I am new to the forum, I have a query about the megaflo eco plus unvented indirect cylinder, if anyone could advise me.
My mains is 32mm and I think I have a flow rate of around 30l/min (whilst my mains are 32mm, all my house pipes are 15mm which will be replaced when the system is installed which might increase the flow rate), whilst I believe this should normally be enough for the megaflo eco cylinder, the eco plus specs state a minimum of 50l/min otherwise it will have reduced performance.
I was wondering if anyone with experience, would know if the reduced performance will simply be a case of waiting longer for the cylinder to replenish its hot water, if there will be any other significant effects, i.e if I have a lower flow rate, will the cylinder work as good as a normal eco atleast (I would rather future proof now and have my mains upgraded at a later point)?
I'm basically looking around different systems before hiring someone to install everything and unfortunately, Heatrae Sadia are closed on the weekend, so was hoping to get some answers before.
