Megaflo (Heatrae Sadia) - Isolating HW to change a tap
29 Mar 2010
Birmingham
Hello,
I'm going to change a kitchen tap and the HW is supplied from a Megaflo.
Shutting off the cold is easy enough as there is a mains shut off inside the house easily accessible. Unfortunately there is no valves present at the sink so I need to shut off the hot water.
Having never worked with a Megaflo before how do I go about shutting off the hot water to change the tap? Anything specific I need to watch out for that you would't normally.
I noticed there was a shut off valve on the inlet side of the tank.
Cheers
You should be able to shut off your incoming water main and that should isolate both the hot and the cold as you have a mains fed cylinder. The hot may take a little longer to stop running due to the pressure built up with in the cylinder. Take the opportunity to fit an isolation valve under the sink. Also there is sometimes a valve before the pressure reducing valve on the cold inlet feeding the cylinder.
Makes sense, thank you for the quick reply.
Nothing to worry about when refilling the tank? Mains pressure on the cold inlet enough to force any air out of an open hot tap?
Will fit an isolating valve under the sink.
Yes, shut off on the cold inlet before the PRV
Cheers
