Hi, It is leaking from the immersion. On investigation it is not the flange but the actual rod of the element where it passed through the immersion heater into the water jacket Got a new one and went to fit it at the weekend but was alarmed by the amount of limescale in the bottom. It wasn't up to the immersion but around 50mm from it. The coil seems clear of limescale apart from the bits of the coil that is buried in the limescale. What I did notice though was a white disc of plastic although wasnt a full circle would imagine that it is something to do with a cover on the floating pressure vessel as the broken off bit that I could see would be roughly the diameter of the internal cavity of the cylinder? Have phoned Heatre Sadia who said it only has a 5 year warranty as no barcode and that it is not a grey top cylinder I would imagine that the stainless from the old ones is better grade than the new once and certainly by what I could see of the heating coil this had no limescale at all. Is it correct that megaflo from yesteryear only have a very short warranty. Certainly wasnt expecting to have to purchase a new one given that my old copper one is 25 years plus and was around 1/7th of the price.
