long story short. bought my house a couple of years ago and am now starting to save up for the big jobs that need doing. I stretched myself and bought a 5 bed but the water heating set up is just too small (house was extended from a 3-bed and even then tank is small).
Have large loft but water tank is smack bang in the middle, so would like to remove this and run everything off the mains.
Long story short I am thinking about getting a megaflo or something like this. i've been trying to do a bit of reading and did have a bit of a chat with a plumber who came round to do another job (he agreed that this was the way to go and that current standard tank is too small). There are 4 of us in the house and so am thinking that I should get a 250L tank.
All the plumbing and wiring is in an airing cupboard with some space available so I am thinking of taking out the current tank and putting an unvented system in there.
I was told that the boiler I have got is plenty powerful enough to run both central heating and tank. This is where I get a bit confused and need some advice/opinions please.
1. Advice on makes. Megaflo/ Ariston - what do the pros on here use and why? Is megaflo just a brand or is there more to it than marketing. Cannot tell when reading their site as I am not a pro.
2. new vs 2nd hand. Basically money is tight. If I can do 2nd hand I will unless there is a good reason not to.What are the watchouts? i'm assuming the age, leaks condition of coil/elements is a factor? If I sit and watch ebay - what should I ask a seller?
3. direct vs indirect. Am just confused. Is indirect powered by boiler with an immersion backup? and direct from immersions only?
Are there big differences in efficiency between the two. Is it a possibilty to just let my boiler run the central heating and have the pressurised hot water tank run from immersion only - or is that silly. Should I get an (direct?) system.
4. Control. Is it likely that I will need to have a new control module installed - am utterly clueless on this point.
5. Water softening - am thinking that this will be the final big appliance and so should prob get water softening into the property at same time - any reasons this is not a good idea?
I'm hoping that I can get a 2nd hand unvented direct system and plug it in to the existing space so I can save money on purchase, install and the running costs won;t be too high. Plus it will be independent of the central heating. So some plumbing some wiring and bobs a close relative? <fingers crossed - but I know life is never that simple>
Thanks for any pointers, would really value any opinions. Again, I have done some reading and spoken to some people and am still genuinely confused.
