On this cylinder are Two cotherm TSE thermostatically controlled immersion heaters.
The lower unit (economy seven) tripped it's internal reset, a few days later the same thing has occurred, so I lowered the temperature on the stat, but still the same problem occurs.
I have swapped the top and bottom stats over to eliminate them as being the problem, but even the exchanged stat trips out...is it possible/likely that the element is intermittently shorting out once warm? I really can't come up with another reason, but would be re-assured by someone having had a similar issue.
Another problem is that the supply is now coming on at 2.30pm - I was led to think that the idea was to use cheaper electricity in the early hours of the morning.
There is no timer in the flat, is there likely to be a timer for the entire block or is this a connection switched by the electricity company?
Any help is appreciated.
