Hello,
Yesaterday morning I noticed a condsiderable amount of hot water pressure drop from the taps. In the evening when I got home from work I tried to regenerate the air gap according to the instructions, but instead of the gurgling I had hot water flowing through the turndish, I didnt think too much of it and carried on holding the release valve for a few more minutes.
Then when I tried the hot water tap, there was nothing flowing, it was like there was no pressure in the megaflo tank. A builder friend reckons that the tank pressure only works when the water inside is hot (I didn't think it works like that) .I turned up the temperature a little and I started to get a little bit of water at the taps, still far from normal though.
Another thing is that I can hear a very low hissing noise coming from the in flow pipe, it's a bit like the noise you get from a pipe when the tap isn't closed properly and there is some water dripping. When I turn off the megaflo inlet isolator valve (which is on the same length of pipe) the hissing stops.
I don't ever remember hearing this noise in the past when the system was working correctly.
This together with UFH wo's is driving me a bit crazy.
Any advice appreciated.
