I have a peculiar problem and I wonder if anybody has any ideas.
I've experimented thus:
The megaflo tank is full of hot water.
Put the kitchen tap on hot, with no other taps on. Temperature at tap is 38ºC (i.e. poor).
Now, with the kitchen tap still running, turn another random *cold* tap on full elsewhere in the house.
Kitchen tap instantly rises to 53ºC (i.e. good - it's quite a way from the cylinder).
Turn the cold tap off elsewhere. Kitchen tap drops like a stone to 38ºC.
I have isolated the hot supply and have confirmed that you don't get a single drip out of the kitchen tap on hot when the hot is isolated - confirming that cold isn't mixing with the hot.
It isn't specific to the kitchen tap - it happens with any hot tap.
Any ideas what may be causing it or how I can rectify the issue?! My cold taps are all fed from the mains cold and the hot is fed from the megaflo, with the standard PRV on the input. Many thanks for any insight.
