megaflo unvented cylinder
9 Aug 2011
Kent
i have just had a grant vortex and a megalo fitted its been working fine up to a couple of months ago when we use the hot water tap and take hot water from the megaflo all is fine but once we turn the tap off hot water is dispersed out of the expansion core unit into the tundish outside this only occurs when the megaflo is filling is there any compertent meagaflo fitters out there that might have come across this problem
You may need to replace the air gap in the unit. There are instructions on how to do this in the MI's.
Heat team show a good video.
Just google megaflo air gap.
Water is discharged from a Megaflow whilst its reheating ( and expanding ) if the air gap has failed.
What you have written says that its discharging "while" its refilling. I dont think thats what you mean!
It refills at the same time as water is used! Turn tap off and it stops refilling.
Tony
