Hi
I'm in the process of major house renovations. Its a 3 bed semi with 1 bathroom, but now I will have a loft ext with ensuite and an kitchen extension with utility room. So, originally I was going to go for a combi as I like the idea of instant hot water instead of waiting for a tank to heat up, but realise that for more than 1 bathroom, there with be flow loss if more than 1 shower is in use. So megaflo it is. The next decision is the size of the tank. I heard/read some stories of the water running out quickly as it is pressurized, so was going to go for a 250 cylinder, but for 2 reasons, am now going for a 210. 1 is that although it is a 4 bed house now, only I live there at the moment and that a 210 will still be fine for a family if I ever have one or if one moves in., the 2nd reason is because the cupboard the megaflo will go in, is 1300mm deep and 700mm wide and I thought it would be better for me (for storage purposes) and better for a plumber, if the boiler sat directly above the megaflo - although plumber would have to get on a ladder, its directly in front rather than, if I put it on the wall on the right (outside wall), not much room to swing round. 210 is 1500 high so still room for a boiler above it. I would be interested to know what plumbers thought about my reasonings here. My next decision is the actual boiler. As I was going for a megaflo, I thought I would then have a system boiler rather than a combi, but I've seen somewhere that combis are better stronger boilers and so its better for me to get a combi which will run my central heating better. i have 8 large radiators, 2 towel rads, plus I will be putting 12m sq water underfloor heating in the extension (100m hose). I also read that I can have only my 2 bathrooms using the megaflo water and then kitchen, utility & cloakroom can use the combi for hotwater. Is this true and how much more effort is it for the plumber bearing in mind there is no pipework as yet to the kitchen, utility, cloakroom.
Mamps
Mamps
