I have a 2 year house with a Megaflow system installed. It has been faultless but recently we have been hearing water running somewhere in the house. It happens at random and lasts for a just a few seconds. There is no sign of any leaks, I have checked all the toilet valves etc and no taps leaks.
That leaves the boiler or the Megaflow.
The condensing boiler is not showing any signs of leaks nor are the radiators.
I have just regenerated the Magaflow. I have to admit that I had not done it before and it took quite a long time for all the gurgling to stop. I gather this should be done probably every year so it was well over-due.
Any thoughts on where the running water noise could be coming from? If there was a problem with the Megaflow air bubble leaking would this cause random quick burst of water into the tank?
