Dear All
Having read numerous threads and advice all over the internet on this I thought I'd join this site as it appears the most informative and start my own one.
Had a megaflow installed during our house refurb as the shower we were able to get from an approx 15 year old floor mounted Worcester combi was awesome (other than if another tap was turned on or toilet flushed etc) so (sadly) assumed it would be just as good from a megaflow which in addition might also allow a shower not to be affected as badly by another outlet being opened.
The old pipework was a hotch potch of lead and 15mm copper with knackered old valve taps dotted around when we used to get a pounding shower from the combi. This was replaced by new bigger bore (22 or 25mm?) pipe from the main in the road the whole way into the house with only 4 x 90 degree bends before it gets to the megaflow on the 1st floor.
Pressure going in is 4 bar+ and flow rate 40 l/min (as measured in front of me by Thames Water both inside and outside the house when it was the old pipework.
Result now = showers nowhere near as good as the old system. Had it all checked by a different plumber to that who installed who reckons we've got 2.8 bar and only 28 l/min coming out the megaflow which is then 2.5 bar and 22 l/min once the other side of the 2 shower mixers.
Sadly i never measured the pressure or flow rate at the shower on the old system.
Needless to say at present i am not happy with the pressure not flow rate and I can not understand why the Megaflow reduces the pressure to 3 bar when many shower products on the market today require 3 bar minimum to work well (Hansgrohe). Having done too much research after the event I now wish I'd done a traditional system with HWT in the loft and stuck a couple of 4 bar monsoon pumps up there but i am where i am now and need to make the most of what I've got.
The pressure reducing valve (PRV) needed started to leak about 6 months after installation. So I relayed the above to the plumber i had to come and fix it who suggested I have the PRV removed and replace it with a double check valve which I pressume would mean I'd get back to benefiting from the full 4 bar+ and having seen the huge restriction inside the PRV water has to pass through perhaps the flow rate would significantly improve. I also noticed inside the PRV there is a non return valve - I was thinking in the first instance just removing that might improve the flow rate somewhat.
Has anyone else heard of removing the PRV on one of these? Given the thing has an 8 bar expansion relief valve for safety, I can't see any major reason not to give it a go other than invalidating the guarantee which quite frankly given I think it's a pretty useless bit of kit wouldn't concern me!
Any advice and suggestions will be greatly received.
Thanks in advance.
MT.
Thanks in advance.
MT.
