With the Megaflow Eco Solar PV with iBoost and 2 x 3kw heaters, do the two heating elements work only one at a time? Manual states 1.5mm heat resistant flex input
is required, but this nowhere near enough if both elements are running?
The iBoost is already prewired to the cylinder with 1.5mm to each, so that's fine, but when making the mains connection 1.5mm seems to small.
Thanks,
Thanks,
