Hi, i've just got a new house and am in the process of renovating.
This is what I want to do and further down is what i've discovered.
I want to put a sheet of pvc or a damp proof membrane on top of the floorboards and seal at the bottom edge of the skirting to stop any smells/draughts coming up from the crawlspace, then put underlay and laminate flooring on top.
I've discovered that the ground floor has a crawl space of about 3feet depth with joists and floorboards on top.
The crawl space has a strong musty earthy smell that seems to come through the boards and into the house.
I've found a hatch in a cupboard and have crawled about a lot of the house and it all seems dry enough with decent airflow, through the airbricks as daylight can be seen easily and it's pretty cold and draughty when your in there.. The joists and floorboards are also in pretty good condition. There's some traces of hard dry efflorescence on some brickwork.
So if there's good airflow in the crawlspace which would stop condensation on the floorboards and/or allow any condensation to dry, this would allow the membrane to be added on top of the floorboards ? And the insulation added on top of the membrane below any laminate flooring would help against condensation from the other direction ?
Any info would be much appreciated.
Thanks in advance
dave
Thanks in advance
dave
