I have an almost horizontaL lead gutter about 70 mm wide between a gently sloping zinc roof and a vertical brick wall. There is a hole in the lead, about 15 mm by 5mm, probably caused when I was cutting away the wood underneath the flat roof, which is rotting. (The water causing the rot is coming in elsewhere.) How can I mend the hole permanently?
