merc ignition
20 Jun 2012
Sussex
I have a Mercedes C Class 220 CDi and the ignition has locked up. I cannot turn the key. It has been suggested that the key needs new batteries and we have them on order but can't help feeling this is wishful thinking. Is this more likely to be the ignition cylinder? Is it a Mercedes job rather than a local garage and any idea of how much this is likely to cost?
is it a auto?
read recently that on some if not all that if it isnt put into park then the keys will not come out??
This is the electronic type key is it?
if a bladed key try a bit of wd40 in the barrel and give the steering a wiggle as you try it
if a bladed key try a bit of wd40 in the barrel and give the steering a wiggle as you try it[/quote
Its the electronic type plastic key
