Hi guys.
This is my process for bonding. Please bare in mind I am no plasterer, just a DIYer that does it myself to save on labour costs. This may be a bit unorthodox but it works for me and i get good results.
The wall is pretty much dead flat until i apply the skim of bonding over the mesh. Then i have to faff about flattening and floating the top layer. I find that bonding is a pain to float if the mix isnt just right or you get it at just the right point of curing. I can get it pretty flat but its not perfect and takes forever.
Finally to my question lol...
Can i apply the mesh, let the bonding dry (i never have time to bond and skim the same day) then pva and multifinish directly over the mesh?
When i bond over the mesh it is obviously all still wet and fuses together so the mesh is well embedded. Im worried if i dont bond over the mesh the multifinish wont adhere to it sufficiently.
- I screw 11mm wooden battens to the wall and get them flat and level.
- Fill between the battens with bonding.
- Use my feather edge along the battens to flatten the bonding.
- Remove the battens and fill in the gaps left.
- Apply plastering mesh to the entire wall.
- Skim over the mesh with a thin layer of bonding.
- Flatten the top layer of bonding with my darby as much as possible.
- Float the bonding.
