Mesh spacers, recommended spacing?
22 Oct 2013
London
What's the recommended spacing between mesh spacers when supporting reinforcement mesh?
Our engineer designed reinforced ground floor slab is 150mm deep and will have A393 mesh 50mm from the bottom. The plan is to use plastic plate spacers to help spread the load over the anti-heave layer and DPM while the concrete is being poured.
The slab is approximately 13.5m2, so I'm hoping a pack of 200 spacers will be enough to support the mesh. The mesh will also be tied onto 16mm dowels on two sides to the existing walls.
Can't you pour a 50mm layer of conc over the site fist and pop the mesh into this?
Or is it that you have to tie it into the dowels making it a prerequisite to pouring the conc, i.e. time frame etc?
Hi, the mesh needs to be tied onto the 16mm dowels, plus the BCO wants to inspect the site to check the reinforcement prior to the concrete being poured.
I was looking to place them around every 500mm and then use some ply sheets to walk on whilst tying the mesh to the dowels to spread the load.
I just want to make sure I don't damage the DPM or anti heave layer whilst fixing the reinforcement.
