As you are using an 8 gang back box, the hole you cut for this will very likely give you enough access into the void to allow you to put some support noggins/timbers across the stud work that can then be used to securely fit the backbox to.
If you cannot access across the stud then you will either need to break into the board to allow you to do this and repair, or you will need to form some timbers around/near to the hole that will then allow you to but fixing noggins across the hole.
