Hi All,
I've chased ut the wall for cables and the metal boxes (for sockets to mount to) and had a couple of questions please:
1. does it mattter if the boxes are below the level of the plaster albeit very slightly? I assumed that this is okay, as long as they are not too deep so that the screws dont reach when mounting a socket. I suspect it's a bigger problem when they are slightlly higher than the plaster...
2. I have used the chisel bit on my SDS to chase out the void for thr metal boxes but they are not perfectly straight which means that when I go to screw them, there is a risk that they may be uneven. How do people ensure that they seat correctly and are flush to the front.
Thanks in advance.
Thanks in advance.
