Metal Corner Bead
10 Mar 2013
Essex
Hi All,
We've recently had a bunch of building work done including our internal walls plastering (some new walls, some skimming over existing walls. All the external corners have metal corner bead on, and whilst the 2 flat sides of the trim are covered in plaster, the very corner still shows the metal edge - is this normal, or should this also be covered? It's caused issues now we're painting (emulsion), because the metal corner isn't taking the paint as well as the flat wall, and so the edge can still be seen.
Thanks in advance for any advice!
