Metal isolation to plastic
11 Mar 2022
Can you fit plastic water pipe to a metal isolation valve?
Thank you
Thank you
Yes assuming the iso valve has compression fittings.
You'll need an insert in the placcie, not all inserts are the same. (So if you have JG placcie pipe, make sure you use JG inserts)
