metal shed guttering
10 Feb 2014
Oxfordshire
Hi all,
Trying to put guttering on a metal shed which is clearly not designed for it. One of the corners where I'd need to drill into to attach a bracket is too close to the fence to get a drill to. From inside I'm not sure I can drill cleanly through as there are several layers if that makes sense.
Would it be worth trying to glue them using something like gripfill?
Cheers!
Your shed consists of box section construction......I'd persevere with drilling from the inside if possible and use a long bolt....Gripfill isn't the best here, Araldite would be better but not if the steel is plastic coated.
Its not possible to move the shed for access, I guess?
John :)
No chance of moving it. Would be far more work than the guttering is worth!
I'll try and drill it from inside somehow.
Thanks!
