I have dismantled a structural frame, and some repair/replacement needs to be done before it can be re-assembled. The frame is of square shape, made from 4 individuel pieces of timber, 2 x 18feet long, and the other 2 x 13feet long. All of them are 4inch square. Incidently the frame lies on the floor and it levelled with packings, it does not stand vertical either. Also it is designed to come apart, as it is held together with pins/wedges.
I have a couple of problems i need help with...
Due to the length of the timber i am having problems getting any replacements. A friend of mine tells me it is in softwood/pine.
He has also told me that the replacements should be Douglas Fir. Any other timbers suitable?
The reason for replacing is due to one 18f long piece has broke in half. And the other pieces are suffering from splitting on the ends.
The ends my friend told me could be repaired if they had 'Metal Shoes' fitted. Can someone please explain to me, or point me in the direction of somewhere on the web, where i can find some information / photos of this? He mentioned it was used in ships?
Also any ideas on how the broken timber could be repaired. Steel plates fitted either side, which have been routered out, then bolted through was one idea.
If the timbers are to be repaired they need to have the paint stripped from them. Any ideas sanding/ chemical removal?
I am concerned they could have been painted with 'lead' based paint.
Any information or help would be much apprieciated.
Many thanks
Many thanks
