- Joined
- 30 Jan 2012
- Messages
- 29
- Reaction score
- 1
- Country
I need to brace across a right angle corner of a DIY uPVC conservatory. The brace will be just above head height and will run horizontally from near the top of one wall across to near the top of another. The purpose of the brace is not really important but has to do with a heavy door that has to open in a particular direction and be hung from a particular place on the wall.
The brace will be in compression. It needs to be about 4 feet long, round or square section and about 1cm diameter.
I can make the brace from steel tube with the ends squashed flat and drilled, but I can't find suitable brackets for fixing neatly to the uPVC at each end.
Anybody got any bright ideas?
