Meter Cabinet
13 Jul 2004
Having a new supply fitted to garage by EDF. I need to have a meter cabinet fitted to the outside wall. Have purchased the cabinet and hocky stick as specified by them. 2 questions
1. Is it upto EDF to seal the whole where the hocky stick enters the cabinet or uo to me/installer - hole in cabinet larger than stick diameter.
2. Do the meter tails from CU (inside garage) need to be in conduit or can they go straight through the wall (no cavity - single brick wall) to the cabinet. Length of tails about 2.5 meters.
ps - will be notified under part P etc etc
Send a letter. You should have an address on your confirmation. if not, use the address on your bill and let them sort it out.
Not so easily fobbed off as a phone call
it will be logged (not lost) and passed along until it reaches someone competent to help
You can send the bimbo along to me.
