Meter no longer required
4 Jan 2009
Herefordshire
I'm putting two flats back into one house. The electric is now all on one meter.
So there is now a spare meter drawing no current.
Do I contact Npower or Western Power to have this meter removed?
What are they likely to do?
Contact your supplier, they'll come remove the meter and pull the main fuse and I would assume, take the tails out of the head.
If you want the head gone too, thats WPD and some £££
Are the meter tails in Henley blocks then?
In that case they'll just remove the meter back to the henley blocks I guess.
If you're luck you might be able to persuade the MOP to replace the tails back to the head, but you'll be lucky.
I had one recently changing a meter, wouldn't add a DP isolator (fitted, with tails ready to go), just told me to cut the seals and do it myself when he'd gone!
